Use the following procedure to configure BFD on an IPv4 static route.
    enable
    configure terminal
  2. Configure BFD on an IPv4 static route:
    ip route bfd {A.B.C.D}
The following table defines parameters for the ip route bfd command.
Variable
Value
{A.B.C.D}
Specifies the BFD static route IPv4 address.
